VPN Client Download
Oct 22nd, 2009
I am looking for somewhere to download the Cisco VPN client from. Specifically the 64x Vista one. Thanks
Todd Pula Thu, 10/22/2009 - 11:41
The Cisco IPSec VPN client does not support 64-bit operating systems. Your only option is the AnyConnect SSL client. Support for this client will require additional configuration on your headend IOS router or ASA.
http://tools.cisco.com/support/downloads/go/ImageList.x?relVer=2.4.0202&mdfid=281278373&sftType=AnyConnect+VPN+Client+Software&optPlat=&nodecount=2&edesignator=null&modelName=Cisco+AnyConnect+VPN+Client+v2.x&treeMdfId=268438162&treeName=Security&modifmdfid=null&imname=&hybrid=null&imst=null&lr=Y
Phillip Remaker Fri, 02/19/2010 - 12:09
64-bit VPN client support is added in 5.0.7, now in public beta
Key Capabilities available for Beta Testing:
New Platform support – Windows 7 & Windows Vista 64-bit platform compatibility
Software Access: http://tools.cisco.com/support/downloads/go/Redirect.x?mdfid=281940730 (under 5.BETA)
Software is available for download by any customer with a Cisco.com SMARTnet™ enabled login.
Patrick0711 Thu, 10/22/2009 - 17:34
There is a free 3rd party IPSEC VPN client that supports 64-bit Windows distributions:
Shrewsoft:
http://www.shrew.net/
I've tested this numerous times with single factor and extended authentication VPN configurations on both PIX and ASA platforms.
