CDR: how can we pull out the older CDR using FTP
Answered Question
Oct 22nd, 2009
We are having a CCM 6.1 system, CDR service activated starting from date Jan 1st 2009. Now recently we have installed a Call Billing software(Proteus). The software reads the CDR raw data from a directory in the local machine.
For the CDR to be loaded to a directory in the call billing server I am running an FTP in the billing server and I have configured the callmanager to load all CDR raw data to this particular Server using FTP.
This is hwo I have configured the CCM
From the Serviceablity page:
Tools---> CDR Management---->
Host Name / IP Address* = 10.34.72.231
user name: cisco
pssword: cisco
protocol: SFTP
Directory Path: /
Now the CDR is being loaded into the Directory in the Billing server. But the problem is that, it only loading the CDR data from the day I created the FTP path that is 19/0ct/09. All the data beginnning from Jan 09 to this date is missing in the bill being generated.
Is there any way that we can pull out the previous data from the CCM, to the Directory in the billing server.
Please Help
Thanks in Advance
Bejoy Thomas
Correct Answer by htluo about 7 years 6 months ago
If you're not familiar with CLI, you may use RTMT (Realtime Monitoring Tool) to download CDR files.
Michael
http://htluo.blogspot.com
Overall Rating: 5 (2 ratings)
Jaime Valencia Thu, 10/22/2009 - 05:02
  • Cisco Employee,
  • Hall of Fame,
    2011
That's WAD, it's the same as CDR. Starts logging from the moment you enable it, anything before is not logged.
There is no config on billing servers to do this, the only way would be to get the flat files via CLI, but i doubt you'll get info from January this way, CDR processed files are only stored 30 days in the server if i recall correctly.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
bejoy.cisco Thu, 10/22/2009 - 05:21
Thanks a lot for the reply....
Also can you plz tell me how to get the files using the CLI.
bejoy.cisco Thu, 10/22/2009 - 05:35
bejoy.cisco Mon, 10/26/2009 - 01:51
Thanks a lot for the solution, it worked, I am able to extract all CDR now, in the required format.
Thanks once again
Bejoy Thomas
