SPA 962 + 932 - power consumption
Oct 22nd, 2009
Going through SPA932 documentation I learned that the SPA932 draws its power from the SPA962 unit it is attached to. That's great.
Now, I was wondering how that affects the power consumption of the whole unit? I mean, I want to connect the SPA962 + 932 to a PoE port and not use an additional external power adapter to power the whole unit.
I also want to be able calculate how many SPA962 + 932 I can connect on a switch that has XXX watts allocated for PoE.
Could you please advise what's the affect on total power consumption from a PoE switch port of adding the SPA932 unit to a SPA962 phone?
Also, if you could direct me to where I can generally find the power consumption of the various SPA phones?
Thanks in advance,
Addie
Alberto Montilla Mon, 10/26/2009 - 05:03
  • Cisco Employee,
Dear Sir;
Power consumption is always below 7 Watts (class 2) for the SPA900 and SPA500 series. Consumption depends on usage and configuration, but it is between 2 and 5 watts most of the cases.
I believe each data sheet has information about power consumption of the phones.
Regards;
Alberto
