ISA server in Cisco firewall DMZ zone
Oct 22nd, 2009
Hi all,
I have a ISA server that is behind firewall and it is connected to the Internet with static command:static (inside,outside) 192.x.x.x 10.x.x.x dns netmask 0 0 in my firewall.Is it possible to add the server to a firewalls DMZ at same time with the command:static (dmz,outside) 192.x.x.x 10.y.y.y netmask 0 0? I appreciate for any help.
Overall Rating: 4 (1 ratings)
Jatin Katyal Thu, 10/22/2009 - 05:24
There should be no issue by adding one more static-nat for DMZ server. But please make sure that we have two different public ip address's for both. If you have only one public ip than you have to configure port-redirection
Plz rate helpful posts-
sfanayei Fri, 10/23/2009 - 00:27
Dear HTH
I tank you for your respons. It seems to help a lot. I will consider it. Tanks again.
Bedst regards Sfanayei
