Licensing issue - CUCMBE Upgrade from 7.0 to 7.1
Oct 22nd, 2009
My upgrade was successful but the Node license is showing as DEMO. I installed the license I recieved via the PAK and rebotted the BE Server, but it still shows up as DEMO.
I am on with TAC, but they can't seem to figure this out.
Has anyone else run into this issue?
htluo Thu, 10/22/2009 - 05:16
  • Red, 2250 points or more
For major release upgrade (e.g. from 7.0 to 7.1), you need "feature license".
Go to System > Licensing > License Unit Report. Look at the last block ("Software License Version"). Do you have any feature license?
Michael
http://htluo.blogspot.com
Rob Huffman Thu, 10/22/2009 - 05:34
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Heath,
Is this causing any issues? I wouldn't think the "Node" License would come into play in a "BE" setup as it is a single node and cannot be changed. Just a thought.
Cheers!
Rob
PS: Michael, wouldn't the "Software Feature License" be required for a 6.x to 7.x upgrade not a 7.0 to 7.1 upgrade?? Just curious. Huff
HEATH FREEL Thu, 10/22/2009 - 06:30
No - the server is up and running. The SW feature still says 7.0 as I understand it only show the major release.
After an hour of so with TAC and Cisco Licensing they did send me a Node License that fixed the DEMO issue.
My question now is - why didn't they send me the Node License along with the Feature licenses?
Also - they send me Unity Connection Licensing and PAK, but the upgrade of CM appeared to upgrade Unity as well. What makes this more confusing is that I did not install any new unity licensing, yet I do not have any licensing issues in unity......
Wow - I'm confused. and so was Cisco.
gary.mattson Fri, 02/05/2010 - 06:16
I've just encountered this exact same issue.  If you still happen to have your case number I'd like to reference it when contacting TAC.  Thanks in advance!
