Multiple DMZ ASA help
Answered Question
Oct 22nd, 2009
We have ASA 5520 Cisco Adaptive Security Appliance Software Version 7.2(3).
Current Config for DMZ is :
interface GigabitEthernet0/2
nameif dmz
security-level 50
ip address x.x.x.1 255.255.255.0
I am using all the physical port & need to add another DMZ Segment. I am planning to configure following :
int gi0/2
no nameif dmz
no ip add x.x.x.1 255.255.255.0
int gi0/2.35
nameif dmz
vlan 35
security-level 50
int gi0/2.36
nameif dmz2
vlan 36
ip add y.y.y.1 255.255.255.0
I have few question regarding above configuration .
1 Am I on right path or not ?
2 When I will remove dmz from Physical interface to logical interface , what happen to my access-list associated with dmz interface ? do I need to recreate it or moving to logical interface will take care of the config automatically.
Thank you
Viral Patel
Correct Answer by scott-goodwin about 7 years 9 months ago
I beleive you will have to recreate the access-group command to re-apply the access-list as the name removal will delete the associated access-group command.
Scott
Overall Rating: 3 (1 ratings)
Correct Answer
scott-goodwin Thu, 10/22/2009 - 05:24
Scott
patelvc7601 Thu, 10/22/2009 - 06:12
I have currently this command applied to access-list dmz_inbound will apply to nameif interface dmz. I am assuming once I make above changes I may have to just reapply .
access-group dmz_inbound in interface dmz
Thank you
Viral Patel
