Call Admission Control on CME
Oct 22nd, 2009
My CME uses tha same ethernet interface for local phone connections and SIP connection to remote PBX - how can I limit the number of SIP calls to the remote PBX without impacting local connectivity
Overall Rating: 5 (1 ratings)
Brandon Buffin Thu, 10/22/2009 - 06:08
  • Purple, 4500 points or more
You can use the "max-conn" dial peer command to control the maximum number of connections over the sip trunk, for example:
dial-peer voice 1 voip
destination-pattern 1...
session protocol sipv2
session target ipv4:1.1.1.1
max-conn 5
This would allow for 5 simultaneous connections through this dial peer.
Hope this helps.
Brandon
hmdavies Thu, 10/22/2009 - 06:15
thanks, as we have multiple dial peers using a single trunk - is it possible to group the peers to have total maximum connections across all peers without limiting each peer? for example 4 peers with max 10 connections, any peer can use up to the 10 connecitons but would then stop the other peers oversubscribing the trunk
Brandon Buffin Thu, 10/22/2009 - 06:36
I don't know of any way to do this for multiple dial peers. One possibility would be to have all calls over the SIP trunk use a single dial peer. There are a couple of ways I can think of to do this:
1. Use an access code for calls going over the trunk, for example have users dial 8 + four digit extension, so dialing 81234 would hit this dial peer:
destination-pattern 8....
max-conn 5
You could then use a voice translation rule to strip the 8 or strip it on the PBX side.
2. You could use num-exp to essentially to the same as the above except the user would not have to dial 8. So, if you're sending 1... and 2... across the SIP trunk, configure the following:
num-exp 1... 81...
num-exp 2... 82...
You can then use the dial peer and voice translation rule suggested above.
Hope this helps.
Brandon
hmdavies Thu, 10/22/2009 - 07:18
aah, that would work - thanks for your help
