Mode change not accepted
Hi There I am trying to configure a tunnel to carry CLNS traffic using the following config
interface Tunnel0
description *** OSI Tunnel to Langley ***
no ip address
clns router isis
isis metric 21 level-1
tunnel source Loopback0
tunnel destination xxx.xxx.x.x
tunnel mode eon
and I am getting an error message of "Mode change not accepted"
The router is a 3825 running 12.4(15)T7
This config is working fine on 3600 routers running 12.2(29b)& 12.2(12)
Anyone else had this problem and is there a fix
Cheers
Mike
Giuseppe Larosa Thu, 10/22/2009 - 10:04
  • Hall of Fame,
    Founding Member
Hello Mike,
use a GRE tunnel instead
tunnel mode gre
on both ends
you may need to tune clns mtu and to disable hello padding to be able to setup IS-IS adjacency
I had used clns mtu 1460
Hope to help
Giuseppe
Peter Paluch Fri, 10/23/2009 - 00:33
  • Cisco Employee,
Hi Mike,
When exactly do you get that error message? Can you perhaps post a complete transcript?
I was able to replicate your configuration without problems on 12.4(12) IOS for 2691 series routers.
Best regards,
Peter
PENNER-DCNKR-02(config)#int tun 0
PENNER-DCNKR-02(config-if)#desc *** OSI tunnel to HX89 ***
PENNER-DCNKR-02(config-if)#clns router isis
PENNER-DCNKR-02(config-if)#isis metric 21 level-1
PENNER-DCNKR-02(config-if)#tun source lo0
PENNER-DCNKR-02(config-if)#tun dest xxx.xxx.x.x
PENNER-DCNKR-02(config-if)#tun mode eon
PENNER-DCNKR-02(config-if)#^Z
PENNER-DCNKR-02#wr
Building configuration...
[OK]
PENNER-DCNKR-02#sh int tun 0
Tunnel0 is up, line protocol is down
Hardware is Tunnel
Description: *** OSI tunnel to HX89 ***
MTU 1514 bytes, BW 9 Kbit/sec, DLY 500000 usec,
Encapsulation TUNNEL, loopback not set
Keepalive not set
Tunnel source 213.186.5.172 (Loopback0), destination 213.186.5.3
Tunnel protocol/transport uninitialized
Tunnel TTL 255
Tunnel transmit bandwidth 8000 (kbps)
Tunnel receive bandwidth 8000 (kbps)
Last input never, output 00:00:24, output hang never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 1
Queueing strategy: fifo
Output queue: 0/0 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
3 packets output, 1625 bytes, 0 underruns
PENNER-DCNKR-02#
Here is the sh hard
PENNER-DCNKR-02#sh hard
Cisco IOS Software, 3800 Software (C3825-IPBASE-M), Version 12.4(15)T7, RELEASE
SOFTWARE (fc3)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Wed 13-Aug-08 23:17 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T11, RELEASE SOFTWARE (fc1)
PENNER-DCNKR-02 uptime is 11 weeks, 2 days, 15 minutes
System returned to ROM by reload at 09:17:05 UTC Wed Aug 5 2009
System image file is "flash:c3825-ipbase-mz.124-15.T7.bin"
Cisco 3825 (revision 1.2) with 226304K/35840K bytes of memory.
Processor board ID FCZ131773AY
3 Gigabit Ethernet interfaces
DRAM configuration is 64 bits wide with parity enabled.
479K bytes of NVRAM.
62720K bytes of ATA System CompactFlash (Read/Write)
Peter Paluch Fri, 10/23/2009 - 02:07
  • Cisco Employee,
Hi Mike,
Two suggestions:
1.) Try to create a completely new Tunnel interface (Tunnel100 for example) and use the tunnel mode eon as the very first command on that interface. Only then try to add the remaining commands.
2.) I noticed that the IOS running on your 3825 is IP Base. Honestly, I am not sure if the EON encapsulation is available in the IP Base feature set. I have been using Advanced IP Services for my experiment.
Best regards,
Peter
Peter Paluch Fri, 10/23/2009 - 02:47
  • Cisco Employee,
Mike,
You are welcome. And thanks for asking - this has been my first "exposure" to the EON type of tunnels. Thanks to you I've learned something new.
Best regards,
Peter
