DTMF CUBE H323-to-SIP problem
Oct 22nd, 2009
Problem Details: My scheme:
cucmbe 7.1
h323 gateway 3825
sip trunk provider
CUCMBE - H323 - GATEWAY - SIP TRUNK
The incoming calls from sip trunk are routed to a unity callhandlers, the input pressed are not reconized...the user press 1 or 2 or 3.....and nothing happens...but internals ip phones
press 1 or 2 or 3...work just fine...
the outbound dtmf works fine...
the problem is inbounds...
I think is dtmf-relay problem...!!!
this is my configuration:
voice service voip
allow-connection h323 to sip
allow-connection sip to h323
h323
emptycapability
h225 id-passthru
h245 passthru tcsnonstd-passthru
dial-peer voice 1 voice
description cucmbe to gateway cube
answer-address .T
incoming called-number .T
dtmf-relay h245-alphanumeric
codec transparent
ip qos dscp cs5 media
ip qos dscp cs5 signaling
dial-peer voice 2 voice
description gateway cube to sip trunk
destination-pattern .T
session target ipv4:200.20.21.200
dtmf-relay rtp-nte
codec g729br8
clid network-number 53197010
dial-peer voice 3 voice
description gateway cube to cucmbe
destination-pattern 3197010
session target ipv4:172.25.51.253
codec transparent
Note: the sip provider have to recive calling number : 53197010 to make calls.
that why the dial-peer 2 have the command clid network-number: 53197010, the outside world communicate with me withn the number 3197010. In the call manager have a translation rule 3197010 to voicemail 555. that why the people calls 3197010 and go to the callhandler unity.
pls help!!!!
Cdbakken1 Thu, 10/22/2009 - 08:39
Try adding the following two statements to your sip dial-peers:
voice-class sip dtmf-relay force rtp-nte
dtmf-relay sip-notify rtp-nte
no promises but this is what we have in our dial-peers and dtmf works both ways.
Hope this helps!
