asa 5510 8.2(1) gigabit interfaces
Oct 22nd, 2009
I'm using a 5510 with sw 8.2(1) and sec plus license. Normally that should give me eth0/0 and eth0/1 as gigabit interfaces.
Unfortunatly it doesn't. I looked in the bug toolkit, but there is nog bug reported. Did someone saw this issue before with sw 8.2(1) ?
snickered Thu, 10/22/2009 - 09:48
I had the same problem... I'm content with it showing "BW 1000 Mbps" on 'sh int e0/0' and 'sh int e0/1' and "BW 100 Mbps" on the others. Why they didn't name them Gi0/0 and Gi0/1 is beyond me.
JORGE RODRIGUEZ Thu, 10/22/2009 - 11:23
You should go to either interface e0/0 or e0/1 and place question mark, and be able to hard code what you need or do
auto/auto at each end.
asa5510(config)# interface ethernet0/0
asa5510(config-if)# speed ?
interface mode commands/options:
10 Force 10 Mbps operation
100 Force 100 Mbps operation
1000 Force 1000 Mbps operation
auto Enable AUTO speed configuration
asa5510(config-if)# duplex ?
auto Enable AUTO duplex configuration
full Force full duplex operation
half Force half-duplex operation
fvanlancker Thu, 10/22/2009 - 11:42
well, I know but I don't have the option:
JORGE RODRIGUEZ Thu, 10/22/2009 - 13:25
What happens when you issue "speed 1000" under the intrface configuration.. the thread I posted was issued under code 8.0.4 , perhaps under 8.2 is to be auto at both ends provided the switch port you connect e0/0 or e0/1 supports gig..
can you post output of show version, strip out asa serial numebr and activation key.
Patrick0711 Thu, 10/22/2009 - 18:25
Do you have other gigabit interfaces configured? The ASA 5510 Sec + with v7.2(3) and above support 2, 10/100/1000 MB interfaces.
Are you certain the security plus license is installed?
gneltnor Fri, 10/23/2009 - 10:06
I had the same exact problem running 8.0(2) code, after I upgraded to 8.0(4) the problem was fixed. Sounds like the bug maybe back with 8.2(1) or the security plus license isn't activated properly.
