Configuring Conditional Advertisement
Oct 22nd, 2009
We need to configure conditional advertisement between two routers running BGP v4. This will enable us to make two ISPs back up to each other.
However we configured two ISPs in two different routers. Do we need a ibgp between routers?
Diagram is duly attached.
We have tried the configuration in our lab, the confirguration is attached with GNS.txt file name.
Unfortunately the configuration did not work for us. we are able to get iBGP routes but it doesnot announce the second prefix when the first ISP is down.
slmansfield Thu, 10/22/2009 - 09:47
  • Silver, 250 points or more
I don't see the attachment of your GNS.txt file. Could you include that? thx
navinder.singh Thu, 10/22/2009 - 10:18
Thank you!!!
I am unable to attache the file, however, it is the same as attached the Net1.gif file, in which 2 routers were configured as ISPs and 2 were ibgp routers.
Giuseppe Larosa Thu, 10/22/2009 - 10:14
  • Hall of Fame,
    Founding Member
Hello Navinder,
generally speaking in a scenario like yours the answer is yes.
second router has to receive BGP routes from router1 however, also router1 receives routes from router2 so an iBGP session is needed but it might not be enough.
post your current config.
there is an attach file options when you create a new post
Hope to help
Giuseppe
slmansfield Thu, 10/22/2009 - 11:09
After reviewing the diagram (which I'm having a hard time reading, so I apologize if I am mis-interpretting something), it looks like the outbound traffic is directed via HSRP between the two gateways, GW1 and GW2.
If you want to manage inbound traffic so it takes a preferred path through one ISP and fails over to the other ISP, I think you could just configure a prepended AS path for the network(s) you are advertising to the Internet over the less preferred ISP path. I don't think you need to make GW1 and GW2 IBGP peers to accomplish this.
navinder.singh Thu, 10/22/2009 - 19:33
Thanks Giuseppe!!
Please find the configuration below
router bgp 24471
no synchronization
bgp log-neighbor-changes
network 203.99.41.0
network 203.99.42.0
neighbor 202.88.238.65 remote-as 17465
neighbor 202.88.238.65 ebgp-multihop 5
neighbor 202.88.238.65 update-source Loopback0
neighbor 202.88.238.65 soft-reconfiguration inbound
neighbor 202.88.238.65 route-map ustr_in in
neighbor 202.88.238.65 route-map ustr_out out
neighbor 202.88.238.65 advertise-map ISP2_out non-exist-map ISP2_down
neighbor 203.99.41.65 remote-as 24471
neighbor 203.99.41.65 update-source Loopback0
neighbor 203.99.41.65 next-hop-self
neighbor 203.99.41.65 soft-reconfiguration inbound
no auto-summary
ip as-path access-list 100 permit ^17465_[0-9]*$
ip prefix-list ISP2_in seq 5 permit 59.144.4.0/24
ip prefix-list ustr seq 10 permit 203.99.40.0/21
ip prefix-list ustr1 seq 5 permit 203.99.40.0/24
ip prefix-list ustr2 seq 5 permit 203.99.41.0/24
ip prefix-list ustr3 seq 5 permit 203.99.42.0/24
route-map ustr_out permit 10
match ip address prefix-list ustr3
route-map ISP2_down permit 10
match ip address prefix-list ISP2_in
route-map ISP2_out permit 10
match ip address prefix-list ustr2
route-map ustr_in permit 10
match ip address 100
slmansfield Mon, 10/26/2009 - 11:32
I think the issue preventing the conditional advertisement from working is the route-map to the same neighbor. That route-map is only advertising 203.99.42.0/24. When the watched route is lost, this route-map still only allows the advertisment of 203.99.42.0/24.
If you either remove the route-map or adjust it to include 203.99.41.0/24 you will find that the conditional advertisement works.
