%Error opening tftp://
Jerry Ye Thu, 10/22/2009 - 09:54
  • Cisco Employee,
Do you mean that you want to copy the running-config to the TFTP server? Can you ping your TFTP server from your switch? If yes, then the command should be something like
copy running tftp://1.1.1.1/SW1_run.txt
jerry
Jerry Ye Thu, 10/22/2009 - 10:12
  • Cisco Employee,
1.1.1.1 is the TFTP server IP address. I just use that as a sample, sorry for the confusion.
jerry
Jerry Ye Thu, 10/22/2009 - 10:47
  • Cisco Employee,
Can you log the screen and show us what you have done?
Please include a ping before trying the copy command.
jerry
thotsaphon Thu, 10/22/2009 - 11:23
  • Gold, 750 points or more
Gopinath,
Hi, How are you doing?
- To make sure that the tftp service is already running. Winbox, a "netstat -an" command will reveal the tftp port that is already waiting for the connection or not. UDP/69 is what you must see there.
- Don't tell me that you're having a personal firewall runing on your computer. Please stop it for a while or try to manaully allow the connection to TFTP port if you can. (grin)
HTH,
Toshi
jfraasch Thu, 10/22/2009 - 11:58
Be sure your local firewall is off and be sure you have your TFTP server actually up and running on the location you are transferring the file to.
Leo Laohoo Thu, 10/22/2009 - 13:27
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
The syntax is "copy ". So if you want to copy the switch config to the tftp server, then it's
copy flash:config.text tftp:///
Alternatively, if you want the running config then it's
copy running tftp:///
Another method is to do a sh run command and log it into a notepad or something. Then save the notepad into the TFTP server.
