TFTP error - configuration backup from switch
gopi_b4u2003
Can anyone adivce to resolve this issue. I am taking configuration backup from cisco 2950 switch through TFTP server. But it is getting error
%Error opening tftp:
How to resolve this issue
Lucien Avramov
Level 10
Level 10
Post all the commands you are entering before you get this error
Leo Laohoo
The syntax is "copy ". So if you want to copy the switch config to the tftp server, then it's
copy flash:config.text tftp:///
Alternatively, if you want the running config then it's
copy running tftp:///
CriscoSystems
Level 5
Level 5
You might have to check your configuration to make sure the tftp-server command is configured.
tftp-server (filename)
where (filename) is the name of the configuration file you want to copy.
(please remember to rate helpful posts)
