IPSec VPN with Dynamic Address
Oct 22nd, 2009
Hi, experts:
I need to create a site to site VPN, but there is one caveat: one end will have a dynamic external interface IP address.
BESIDES DMVPN, is there another way of working around that?
How can I get the two routers to establish an IPSec tunnel betwen them if one router does not know how to reach the other? How can IKE phase 1 create an SA?
Someone mentioned certificates as a solution, but I am not sure I understand how this helps.
Anyone?
thotsaphon Thu, 10/22/2009 - 10:11
Joe,
You can do it for sure. What you have to know is that the dynamic-ip side must firstly start sending traffic to the static-ip site. Forgetting about certificates for a while. Let's start finding the "dynamic-map" keyword. You can do it on Cisco IOS firewall or ASA firewall. Let's do some more browsing on Cisco website you will find the way to go.
If I were you,I will check things here : http://www.cisco.com/en/US/products/ps6120/prod_configuration_examples_list.html (grin)
HTH,
Toshi
