SIP phone registration directly on SRST Router
Oct 22nd, 2009
Is it possible to register a SIP phone directly on SRST without registering
it on the Call Manager?
Pls suggest any doc or url that explains the same.
Jaime Valencia Thu, 10/22/2009 - 10:39
  • Cisco Employee,
  • Hall of Fame,
    2011
SRST is only to be used as fallback when CUCM is down, if you're looking to use the router for call control at all times then you need CME and not SRST
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
