DMA 7.1(3) and missing key
Oct 22nd, 2009
I'm trying to track this DMA error down, would I use SQL Enterprise Manager to track it down?
***> DATA PROCESSING TESTS REVEALED AN ISSUE WHICH GENERATED THE FOLLOWING EVENT:
The error number is: [-691]
The error message is: [-691 Missing key in referenced table for referential constraint
The following additional event information is available:
This record was not processed because another record it needs,
(see reference name listed below), is missing. This likely may be due to a previous error
already reported in the log above, or the result of Directory Services Export issues
reported separately, or due to missing Product, Locale, or other add-on definition CSV
files that should exist on the source system but do not.
SUGGESTED ACTION: Resolve all prior reported issues. If none, look at the Suspected Field,
if listed, for an indication of what data reference could not be resolved. Some hints:
- if ...DirGroup related, check for a Directory Export failure
- if ...Locale related, check for a missing Locale Plug-In
Re-execute DMA when all other issues are addressed.
Suspected Field/Item Is [DMABack_Admin.fk_enduserdevicemap_fkenduser]
TABLE NAME IS [EndUserDeviceMap ]
defaultprofile 'F'
description ''
fkdevice '5afcaa0b-775c-4274-b91c-4710dc46beae'
fkenduser '8ab29d17-e305-4bb2-bc2a-4566e2f58a9b'
pkid '4ecaccd8-c242-4b20-86f5-7402e3cd2cd2'
tkuserassociation 5
