WAAS NM-WAE License?
Oct 22nd, 2009
Hi friends, sorry if this is a silly question, I have a C2811 with a NM-WAE-502.
How can I check is the license is an Enterprise or transport?
If I have a transport license, How can I upgrade to Enterprise License?
Thanks for the info guys
David
Overall Rating: 5 (1 ratings)
dstolt Thu, 10/22/2009 - 11:22
David,
On 4.1.x, you should do a "show license" and it will show you the output like this...
WAE1#sh license
License Name Status Activation Date Activated By
Transport not active
Enterprise active 06/09/2009 setAtUpgrade
Video not active
If you only have transport license registered, but purchased the Enterprise license, then you can clear the license and add the Enterprise. (clear license ....., add license ....).
Hope that helps,
Dan
david-lima Fri, 10/23/2009 - 06:58
Hi Dan, thanks for your great post. Actually I'm running the NM-WAE 4.0.17 version, is it possible to check the license type and upgrade it if it is the transport license?
Thanks again
David
dstolt Fri, 10/23/2009 - 18:52
David,
That should make it much easier. WAAS 4.0.x doesn't have any of those commands, your box should already be running the Enterprise License. Really the only way I can think of to check it is to attempt to add the CIFS Edge service to it and see if it enables.
The NME-302 only could support transport license, however the NME-502 usually already had enterprise license enabled.
Dan
