Rob Huffman Thu, 10/22/2009 - 11:48
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Gary,
The "No answer ring duration" only comes into play in conjunction with a "Forward No Answer" setting under the DN config. If there is no "Forward No Answer" setup the phone will ring forever until the far-end hangs up :)
Cheers!
Rob
gmcleveney_2 Thu, 10/22/2009 - 12:07
Rob,
Thanks for quick reply.
What is the setup required? CSS and number for CFNA or one of them ?
Rob Huffman Thu, 10/22/2009 - 14:44
  • Hall of Fame,
    Founding Member
Hey Gary,
No worries my friend! Yes, the Forward No Answer configuration requires a Directory Number entry (or Voicemail checkbox if using VM) and an applicable CSS, usually something restrictive that cannot reach off-net.
Cheers!
Rob
