chris unger Wed, 10/21/2009 - 11:50
well, I guess time to call TAC
Will update group once I get through something that sounds SO simple
Saurabh Verma Thu, 10/22/2009 - 11:45
  • Silver, 250 points or more
Hookflash is enabled by default on UC 500s. When you receive a call-waiting tone, you could select the "Flash" softkey to put the current call on hold and accept the second incoming call. Softkeys on 7921 IP Phones are activated by using the right softkey button that launches the "Options" menu.
HTH,
Saurabh
infoestrie Thu, 10/22/2009 - 18:34
Can you help me,
I have 7975G 7940G SPA521 and SPA509, i can find any softkey for flash my fxo trunk.
How can verify if the fonction is enable or disable in my UC520 ?
Thank You !
Saurabh Verma Fri, 10/23/2009 - 09:47
Hookflash, feature is enabled by default on UC 500s. One way to check this will be to go to CCA:
Troubleshoot > Telephony Diagnostics > IOS Exec Commands
In the command bar, go ahead and paste "show telephony-service" and click on Run. In the output, look for "fxo hook-flash". If that's enabled, then the UC 500 is configured with this feature. If this is not enabled, then it must have been removed manually and you will need to configure this through CLI (or you can restore the system to its default to have it enabled). If there are any changes done, you may need to restart IP Phones for new changes to kick in.
Saurabh
infoestrie Fri, 10/23/2009 - 13:15
After Reset my uc520
i can find any soft key for flash my fxo.
This is my config for telephony service
Thank you !
Daniel
UC520#show telephony-service
CONFIG (Version=7.1)
Version 7.1
Cisco Unified Communications Manager Express
For on-line documentation please see:
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/tsd_products_support_serie        s_home.html
ip source-address 10.1.1.1 port 2000
ip qos dscp:
ef (the MS 6 bits, 46, in ToS, 0xB8) for media
cs3 (the MS 6 bits, 24, in ToS, 0x60) for signal
af41 (the MS 6 bits, 34, in ToS, 0x88) for video
default (the MS 6 bits, 0, in ToS, 0x0) for serviceservice directed-pickup
service dnis overlay
service dnis dir-lookup
load 7960-7940 P00308001000
load 7975 SCCP75.8-4-2S
load 521G-524G cp524g-8-1-17
load 501G spa5x5-7-1-3c
load 502G spa5x5-7-1-3c
load 504G spa5x5-7-1-3c
load 508G spa5x5-7-1-3c
load 509G spa5x5-7-1-3c
max-ephones 14
max-dn 56
max-conferences 8 gain -6
dspfarm units 0
dspfarm transcode sessions 0
conference software
privacy
no privacy-on-hold
hunt-group report delay 1 hours
hunt-group logout DND
max-redirect 5
voicemail 299
cnf-file location: system:
cnf-file option: PER-PHONE-TYPE
network-locale[0] US   (This is the default network locale for this box)
network-locale[1] US
network-locale[2] US
network-locale[3] US
network-locale[4] US
user-locale[0] US    (This is the default user locale for this box)
user-locale[1] US
user-locale[2] US
user-locale[3] US
user-locale[4] US
srst mode auto-provision is OFF
srst ephone template is 0
srst dn template is 0
srst dn line-mode single
phone service videoCapability 1
moh flash:/media/music-on-hold.au
time-format 12
date-format mm-dd-yy
timezone 5 Pacific Standard/Daylight Time
secondary-dialtone 9
url services http://10.1.10.1/voiceview/common/login.do
url authentication http://10.1.10.1/voiceview/authentication/authenticate.do
call-forward pattern .T
call-forward system redirecting-expanded
transfer-pattern 9.T
transfer-pattern .T
keepalive 30 auxiliary 30
timeout interdigit 5
timeout busy 10
timeout ringing 180
timeout transfer-recall 0
timeout ringin-callerid 8
timeout night-service-bell 12
caller-id name-only: enable
system message UC520
web admin system name cisco  secret 5 $1$LueE$BYPOgzzgSJk4ep/WZBDMN0
web admin customer name Customer
edit DN through Web:  enabled.
edit TIME through web:  enabled.
Log (table parameters):
     max-size: 150
     retain-timer: 15
create cnf-files version-stamp 7960 Oct 23 2009 12:53:56
transfer-system full-consult dss
transfer-digit-collect new-call
multicast moh 239.10.16.16 port 2000
auto assign 10 to 19
auto assign 5 to 8 type anl
fxo hook-flash
local directory service: enabled.
Extension-assigner tag-type ephone-tag.
UC520#
Saurabh Verma Fri, 10/23/2009 - 14:25
Hi Daniel,
Did you look for the flash softkey when you had another call come in on an active FXO port? The flash softkey will only appear when there is a call-waiting on an active call that traverses through one of the FXO ports.
Saurabh
infoestrie Fri, 10/23/2009 - 14:37
Yes,
When i place the call from my 7975G in one FXO, i can find any soft key for Flash. When i receive another call form the same FXO, i can find any soft key. I have only HOLD, ENDCALL, TRANSFER, CONF, OTHER => ACCT PARK
Thank !
Saurabh Verma Fri, 10/23/2009 - 14:55
Does the IP Phone display change when you receive the second call? I want to make sure that the second call is coming in on the same FXO port. Some of the voice and phone debugs could be helpful in pin-pointing the issue.
Saurabh
infoestrie Fri, 10/23/2009 - 15:30
When i make debug for my fxo port : debug vpm all
He have no message when he have call waiting ?!@!@!? in the fxo port
Do you have any command for sensibility of call waiting signal ??
Thank.
I use for my line the Videotron phone line (modem with fxs connection)
Thank you
infoestrie Sat, 10/24/2009 - 08:37
The problem is with the version of CCA 2.0.1. After i install and reset with version 2.0 and the flash soft key is in my phone !!!
Thank
Daniel Grimard
Saurabh Verma Mon, 10/26/2009 - 07:53
The only command that's required to enable hook-flash is"fxo hook-flash" configured under telephony-services. This command is not altered by CCA and is enabled in the default configs. I will double check with the engineering team on this.
-Saurabh
chris unger Mon, 10/26/2009 - 11:22
not as simple as you would expect.  Since I was using a 7921 phone, the XML had to be edited and deleted?  the case number with TAC was 642777363
Would love a better explination then I got...  which was none.
thanks
Related Content
