3750 switch stack with 10 linksys roouters
Oct 22nd, 2009
Hello as a temp solution can I use 10 linksys routers with dhcp scopes patched to a 3750? Or can I use a 3750 as the dhcp server? Do I have change my ios for it to dhcp serve?
Overall Rating: 5 (1 ratings)
Giuseppe Larosa Thu, 10/22/2009 - 12:33
Hello David,
you should be able to define 10 DHCP pools locally on the C3750.
you shouldn't need an IOS upgrade.
if you post sh ver | inc image
from C3750
or you can check by yourself using
Feature Navigator
www.cisco.com/go/fn
see
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_46_se/configuration/guide/swdhcp82.html#wp1320911
you can even enforce ip address assigned on a per port basis
Hope to help
Giuseppe
