Can't make Cisco work with my Nortel switch
Answered Question
I have a Nortel Route Switch 8661 and trying to connect to a Catalyst 3750 24 Gig ports.
Have tryied several of the 24 RJ-45 ports and the link doesn't come up.
If I connect a PC to the 3750 then it works. I'm trying to establish a 100Mb link between these two.
Have someone seen this before. Thanks?
Correct Answer by jbrenesj about 7 years 10 months ago
3750 does MDIX so you can use straight-thru cables when connecting to switches together but there is one requirement:
The speed/duplex on the port should be left auto/auto because if you hardcode to a fix speed then MDIX might mis-behave.
Not sure what your settings are on the Cisco switch?
Overall Rating: 5 (1 ratings)
Reza Sharifi Thu, 10/22/2009 - 13:29
  • Cisco Designated VIP,
    2017 LAN
Pc to switch straight through cable
Try using a cross over cable for switch to switch and let us know.
Reza
Correct Answer
jbrenesj Thu, 10/22/2009 - 13:38
  • Silver, 250 points or more
Jerry Ye Thu, 10/22/2009 - 13:44
  • Cisco Employee,
Did you hard code the switch to 100/FULL? MDIX will not work with hard coding the interface, you have to leave it at AUTO/AUTO.
jerry
