ACS Password Change
Answered Question
Oct 22nd, 2009
I'm using ACS 4.2 appliance. Can users log-in to the appliance via web to change their passwords? Or UCP is needed?
Correct Answer by Jatin Katyal about 7 years 9 months ago
Yes, you need UCP implementation since you want that your ACS internal user should change their password on their own.
UCP# You use the UCP application to allow users to change their ACS passwords with a web-based utility. When users need to change passwords, they can access the UCP web page by using a supported web browser. For information about web browsers that we tested with ACS, see the release notes for your ACS product.
HERE ARE THE STEPS
For configuring UCP
--> create two folders in C:\Inetpub\wwwroot\
1)secure
2)securecgi-bin
--> Create two virtual directories
1)secure (Read only access)
2)securecgi-bin (Read only & execute access)
--> install the UCP utility, while installing utility it will prompt for that path where the directories are located
1) http://x.x.x.x/secure
2) http:/x.x.x.x/securecgi-bin
also the ip address of the ACS server.
test the UCP
http://localhost/securecgi-bin/login.htm
MORE INFO:
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_server_for_windows/4.2/installation/guide/user_passwords/ucp.html#wp1041168
INSTALLATION GUIDE:
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_server_for_windows/4.2/installation/guide/user_passwords/ucpNW42.html
JK
Plz rate helpful posts-
Overall Rating: 5 (1 ratings)
Correct Answer
Jatin Katyal Thu, 10/22/2009 - 14:53
  • Cisco Employee,
HERE ARE THE STEPS
For configuring UCP
1)secure
2)securecgi-bin
test the UCP
MORE INFO:
INSTALLATION GUIDE:
JK
