Logging levels
Oct 22nd, 2009
What is your logging level set to on switches? I'm thinking of logging everything to the syslog for my server farms and core switches because I don't want anything to be missed. However I was thinking of something more extreme for my access layer switches. I don't want to see messages everytime someone reboots a PC.
Overall Rating: 4 (1 ratings)
simontibbitts Sat, 10/24/2009 - 23:50
  • Silver, 250 points or more
Hello
Normally access switches do not create any logs during normal operation besides when user ports go up or down. I find it good practice to configure all users ports with the following interface mode command:
no logging event link-status
That way you still get notified if one of your uplinks goes down and then also I find no more logs are generated unless something goes wrong like a port violation or duplex mismatch
hope that helps
Simon
rshum Mon, 10/26/2009 - 06:55
Simon
Thanks for that, I wasn't even aware of that command.
I would agree with you that normally functioning networks logging from the access layer switches wouldn't be necessary other than perhaps major events and core dumps but I have a bit of an abnormal network.
