ASA 5510 subinterfacing for gateway port
Oct 22nd, 2009
Dear Frnds ,
Can i use subinterfacing for two isp links for the one physical port , due to that i am able to use two isp iinks same time. If any configuration is there then please send me.
Panos Kampanakis Fri, 10/23/2009 - 06:27
  • Cisco Employee,
You can subinterface 2 ISP links. Though you will need a switch in front of them to make sure you put them in 2 different vlans, which will be for the subinterfaces.
Here is the guide that explains it http://www.cisco.com/en/US/docs/security/asa/asa80/configuration/guide/intrface.html#wp1044006
interface gigabitethernet 0/1
no shut
interface gigabitethernet 0/1.100
vlan 100
nameif isp1
security-level ...
ip address ...
no shutdown
interface gigabitethernet 0/1.101
vlan 101
nameif isp2
security-level ...
ip address ...
no shutdown
I hope it helps.
PK
shridhar76 Fri, 10/23/2009 - 09:16
Dear Friend ,
Thanks for you techhelp let me know one more thing can you tell me the how can we route the traffic through these created subinterfaces. Please send me that configuration also.
shridhar
