DND and HOLD button misding in Softkey
Oct 22nd, 2009
I am configuring the CM ver 7. I have found the DND and Hold Button is Softkey template seems to be missing.Can any one pleae let me know how to enable this button
Faizal
Jaime Valencia Fri, 10/23/2009 - 05:41
  • Cisco Employee,
  • Hall of Fame,
    2011
Configure the softkey profile and make sure you're trying to configure them in call states where they can be enabled.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
faizal_vi Fri, 10/23/2009 - 08:37
Can you please tell me what exactly you mean by "call states".
Faizal
faizal_vi Fri, 10/23/2009 - 11:54
Hi javalenc
the issue is resolved..thanks for the response.
Faizal
