Config fetch Failed
Oct 23rd, 2009
Added two nex nodes on LMS 2.6.
Passed Credentials but for Telnet got: Protocol not configured. Through command line it works.
IP's are and
Best Regards.
Overall Rating: 4 (1 ratings)
Sven Hruza Fri, 10/23/2009 - 03:14
Is it right, that the IP ..153.253 is your LMS server?
I assume that you deleted the user/pw configured on the device, right?
Is it possible to do a telnet session out of the device center?
mserranocisco Fri, 10/23/2009 - 03:24
YOu are right, we deleted user/psswd to send the file here, for security reasons.
The ip you mention, is our NNM server, CW LMS is 153.254. is a WS-C3560E-48TD, is a WS-C3750G-48TS, both supported on RME 4.1.1, it's a LMS 3.01, I was wrong when I wrote 2.6, sorry...
Sven Hruza Fri, 10/23/2009 - 03:37
Okay, if your LMS is the IP 254 you have to configure that IP on your ACL 1 because you have the "access-class 1 in" on line vty 0 4.
