ACS 5.0, Identity Groups within Access Services Authorization
Oct 23rd, 2009
At the moment I'm evaluating ACS 5.0.0.21 (Eval-Version).
I defined a Service Selection that leads to an Access Service named "DeviceAdmin".
Within this I defined Authorization Rules (Standard Policy) with Conditions an Identity Group and/or UserName.
The problem ist that they never match.
Even if I define an (existing) Identity Group (also All Users) or an (existing) Username, the Authorization Policy always hits to default rule.
Any hint, what's wrong? A known bug?
jrabinow Mon, 10/26/2009 - 16:06
Can you clarify which identity store you are authenticating against in the identity policy?
Also a good place to look for troubleshooting is at:
Monitoring & Reports: ... > Reports > Catalog > AAA Protocol > RADIUS_Authentication
Get to see a list of all recent attempts and any failure reasons. Can select the magnifying glass icon to drill down on the details of the request processing
stephan.ochs Tue, 10/27/2009 - 00:07
Thanks for your reply.
Yesterday I purged all identity groups, applied them again and it worked.
