PIX Authorization issue
Answered Question
Oct 23rd, 2009
Using AAA on a PIX, authentication works fine and the AAA user has full rights over PIX, but aaa authorization always fails when going into conf t
Correct Answer by Jatin Katyal about 7 years 8 months ago
This happens when we have command authorization enabled on ASA
and try to run any level 15 command on ASA.
Please check the ASA configuration and see if you are missing this command:
aaa authentication enable console LOCAL
on the ACS make sure that enable level privilege is level 15
JK
Plz rate helpful posts-
Overall Rating: 5 (2 ratings)
Jatin Katyal Fri, 10/23/2009 - 06:03
  • Cisco Employee,
If this is a ACS user, you need to add this on ACS
Under shared profile component > shell command authorization set > type
"configure" under unmatched commands: and type permit terminal under the permit unmatched args and make sure this has been applied on the user or group and then try again.
JK
networker99 Fri, 10/23/2009 - 07:05
Access is still denied. The restricted group works.. (unable to get into enable mode), but the full access group can get into enable mode but not conf t
Jatin Katyal Fri, 10/23/2009 - 07:11
  • Cisco Employee,
For the full group you just need to do this:
Under shared profile component > shell command authorization set > select the radio button permit.
If that doesn't works please send the screen shots of full access command set.
JK
Plz rate hopeful posts.
Jagdeep Gambhir Fri, 10/23/2009 - 07:14
  • Red, 2250 points or more
Issues seems to be with command authorization. It would have been better if running config is included in the original post.
What message do you see on acs failed attempt?
Any ways , please apply command set (that allows all command) on user level instead of group level.
or
Check the failed attempts and see which group you are a part of, then apply command set to that group.
Good luck!
~JG
Do rate helpful posts
networker99 Fri, 10/23/2009 - 07:16
networker99 Fri, 10/23/2009 - 07:58
In the log my username shows up as "enable_15" ?? and says user unknown?
Correct Answer
Jatin Katyal Fri, 10/23/2009 - 08:03
  • Cisco Employee,
JK
networker99 Fri, 10/23/2009 - 08:07
What will this command do?, Does it make me use my own individual enable password?
Jagdeep Gambhir Fri, 10/23/2009 - 08:10
This command is needed to make command authorization work.
Yes, you can set your own enable password.
~JG
Jagdeep Gambhir Fri, 10/23/2009 - 08:07
Same issue was reported sometime back aswell.
Make sure you have enable authentication ,
aaa authentication ssh console TACACS LOCAL
aaa authentication telnet console TACACS LOCAL
aaa authentication enable console TACACS LOCAL
aaa authorization command TACACS LOCAL
Incase it does not work pls get aaa config
~JG
Jatin Katyal Fri, 10/23/2009 - 08:38
  • Cisco Employee,
yes, if you have separate enable password configured on the ACS, it will let you use that. But i would also suggest you to keep your current session open and try from a duplicate session...just a back door entry.
JK
Omar Badawi Wed, 06/08/2011 - 02:33
i had the same problem, i could login to the ASA using ACS and i went to enable mode using the local enable password, however, i somehow was no longer authenticated as the username i used, but my username shows enable_15, and i couldn't authorize any command, so i created a new user on the ACS (enable_15) and everything worked smoothly.
i don't think this is the solution, but it's working now.
i don't know why the username switches to enable_15, maybe because i am entering the enable secret which is local on the ASA
