delays with L2L VPN when applying encryption
Oct 23rd, 2009
I have a setup where L2L IPSEC tunnel is established between two routers. The problem is that when we apply encryption, there is a very high increase in the delay between the two sites. Please advise what could possibly be the problem knowing that I already did the below without success:
- Changed the hash and encryption algorithms
- Modified the mtu with the TCP-MSS-adjust command
Collin Clark Fri, 10/23/2009 - 06:02
  • Purple, 4500 points or more
What model are the routers? Do they have the AIM encryption module installed? What are the resource being used w/o VPN? Then with VPN?
k.abillama Fri, 10/23/2009 - 22:41
Hi, the HQ router is a 3845 router running IOS c3845-advsecurityk9-mz.124-15.T7.bin without AIM module and the branch router is a 2811 router running IOS c2800nm-advsecurityk9-mz.124-15.T7.bin without AIM also.
The tests being used are mainly file transfers and icmp echoes as well
