Erase VTP Config on VS-S720-10G
Answered Question
Oct 23rd, 2009
I know the VTP config can be erased on most Cisco switches simply be deleting VLAN.DAT. I would like to do this on the VS-S720-10G. I see VLAN.DAT in the const_nvram: file system, but I can't delete it. Does anyone know how to toast the VTP config on a VS-S720-10G, i,e,. return it to factory default?
Correct Answer by Collin Clark about 7 years 3 months ago
Overall Rating: 5 (1 ratings)
Collin Clark Fri, 10/23/2009 - 06:24
VLAN.DAT is the file that contains your VLANs. VTP is VLAN Trunking Protocol. Are you looking to remove your VLANs or disable VTP?
drhague Fri, 10/23/2009 - 06:38
I want to remove all my VLANs, NULL the VTP domain name, and set VTP mode to SERVER. This can all be accomplished on a 3750 by simply deleting VLAN.DAT. I realize I can do a "no vlan 2-1000" and "vtp mode server" to accomplish most of this, but the VTP domain name can never be NULLed unless VLAN.DAT is removed.
cbeswick Fri, 10/23/2009 - 06:28
Does changing the VTP mode to transparent and then back again to client or server reset the database ? or does this just reset the revision number ? I cant remember.
