SNMP traps
Oct 23rd, 2009
Dear all,
I am using CCM 6.1. and In my network we are using third party NMS( Tivoli).
I want to send the traps for IP Phones to that NMS.
For that what I should configure in my CCM.
Ip attaching, what I have done for SNMP configuration in my CCM.
any body is there to help me out.
Thanks & regards
Madhab
jpinkus Mon, 10/26/2009 - 07:58
You have to enable clogNotificationsEnabled (1.3.6.1.4.1.9.9.41.1.1.2) and then the traps will be sent to their destination as defined.
Joe
cisco.madhab Tue, 10/27/2009 - 08:07
Dear Joe,
Thanks for your reply.
can you tell me from which option I can enable that ClogNotification .
thanks & regards
madhab
jpinkus Wed, 10/28/2009 - 06:38
Hi Madhab,
For any dos prompt:
To enable trap (clogNotificationsEnabled) : snmpset -c public -v 2c 1.3.6.1.4.1.9.9.41.1.1.2.0 i 1
To change the trap severity (clogMaxSeverity) : snmpset -c public -v 2c 1.3.6.1.4.1.9.9.41.1.1.3.0 i 4
In above example last value 4 means set the severity to 4 (Error). In this example any syslog event with severity emergency(1),alert(2),critical(3),error(4) will generate the syslog trap.
Joe
