Imagine I have some switches it may be setup as "crypto key gen rsa size = 512". I need to have them setup as 800 bits instead. The problem is that I have hundreds of switches in my environment to verify. Which tool can help me check this and better yet, make sure that all switches are consistently set as "crytpo key generate rsa = 800 bits"?
Is Ciscoworks the right tool to check this type of setting?
