Denying AAA Clients to a specific user group in ACS v4.1
DAVE GENTON
Level 2
Level 2
Using 4.1 is there a "simple" method of simply denying a usergroup the ability to even login to specific AAA clients? Customer has a telephony group that they want to allow them to telnet and check into all the voice routers, but no other routers, they have the command sets and all that setup but wanted to see if a way to push that group simply to voice routers only ??
thanks in advance,
dave
2 Accepted Solutions
Jagdeep Gambhir
Level 10
Level 10
Jatin Katyal
Why don't you use NAR (Network access restriction)
Under the network config > simply create one NDG and assign all the voice router under it.
After that go to the group/user where you want to put this restriction
You need to check that what are we getting in calling station id. If we are getting ip address then
[1] To accomplish above we would configure the group with following
NAR (network access restriction)
Define IP based Network Access Restriction
Permitted Calling Point
AAA client: VOICE NDG created
Port *
Src IP Address *
Subit the changes and try.
Here is more on configuring Network Access Restriction:
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_server_for_windows/4.
2/user/guide/GrpMgt.html#wp478900
JK
Plz rate helpful posts-
~Jatin
13 Replies 13
Jagdeep Gambhir
Level 10
Level 10
You can set it up using NAR in ACS.
http://www.cisco.com/en/US/products/sw/secursw/ps2086/products_tech_note09186a0080858d3c.shtml
~JG
Do rate helpful posts
I looked at that, but isn't that just simply "network restriction" I want them to be able to login to all voice routers and execute the "allowed" commands we have listed, but if they login to a data only router, to get denied access altogether, make sense ?
Just checked your reply.
Well, you need to go bit tricky, looks like that you have data and voice routers and you want no access to data routers and restricted access to voice routers.
Check this::
Create two NDG's one for voice routers and other for data router's.
Go to the group > apply NAR on data routers with action as denied. If we are getting anything apart from valid ip address than you have to use CLI/DNIS based NAR.
since you have command set created with specific commands > on the same group > scroll down to the Shell Command Authorization Set
Assign a Shell Command Authorization Set on a per Network Device Group Basis
Here you can map VOICE router's NDG with respective command authorization set.
So this way we can denied access to data routers and restricted access to voice router's.
JK
~Jatin
Jatin Katyal
Port *
Src IP Address *
JK
~Jatin
Thanks I will give that a shot, that's what was hanging me up on the NAR was that it showed CLID/DNIS but they are local telnet users...
What do the stars mean, is it a wild card?
If I select deny access and all AAA clients and apply it to a group. Does that mean that they will not have access to the AAA client? ie they will not be able to authenticate and log on to a router.
Yes it is a wild card.
Yes, if condition is deny for all aaa-client then that group will not have access to all clients.
Access denied.
~JG
Hi Kelvin,
You got it right. * means wildcard and if we use (*) for port and source address then it would assume any port/address.
If you use action as deny for all aaa client then users of that group in ACS will not able to access any device.
JK
~Jatin
OK thanks that's what I was hoping. One more question, if I have remote access VPN on an ASA and authentication is provided via the ACS and I add the NAR as I described earlier would those users in the group still be able to authenticate?
Hi kelvin,
They will be able to connect if you are using ASA for VPN using radius protocol.
JK
~Jatin
I am guessing if it is using TACACS then it is going to be a problem, am i right?
Kelvin,
You are correct. If we are using tacacs for both the sessions then this would not work because rem_address would be same and that will not allow the vpn users because NAR is there.
JK
~Jatin
ACS 3.2 does not have device groups so I cannot separate the devices.... thanks a lot I'm gonna have to think about it some more.
