Blacklist netmask: ASA5510 botnet filter
congressgroup
I am testing IP blacklists through the botnet filter.
If I try to add:
62.5.128.0/17
to the blacklist - I get the error message 'The netmask is not valid'. Can anyone explain that? I mean, that is a valid netmask is it not?
Kureli Sankar
http://www.subnet-calculator.com/subnet.php?net_class=A
That is correct.
What command are you trying to add?
dynamic-filter blacklist
I just tried to add it and it worked:
5505(config)# sh run dynamic-filter
address 62.5.128.0 255.255.128.0
check command reference here:
http://www.cisco.com/en/US/docs/security/asa/asa82/command/reference/d2.html#wp1909142
Perhaps it is a problem with the ASDM interface. I will try to connect directly and see if the command line is better.
