Issue with a Cisco 837
Answered Question
Oct 23rd, 2009
Hello Folks!!
I have a problem with a cisco 837. When I connect the device to ADSL line, the CD led is off, the TX and RX leds are blinking. On the ADSL line exist other router that I want to replace with it and this other work fine.
Could somebody help me please?
Thanks in advance!!.
Correct Answer by Paolo Bevilacqua about 7 years 2 months ago
No, it would not.
Overall Rating: 4 (2 ratings)
elias.manchon Sat, 10/24/2009 - 00:06
Hi p.bevilacqua
I cannot run "show dsl interface" on the router, because it's in the other business. But I have to say you that I suspect that DSL line is a ITU G.992.5 and I think that this router model not support this line type. This reason is sufficient for the cd led is switch off?.
Thanks in advance.
Paolo Bevilacqua Sat, 10/24/2009 - 00:30
If should synchronize nevertheless at a lower speed. There is newer firmware that you can try.
elias.manchon Sat, 10/24/2009 - 00:46
Where is the firmware?. I had understood that this model not supported ADSL2+. Then I'm wrong about this question?.
Thanks.
elias.manchon Sat, 10/24/2009 - 04:30
You want to me that I update my firmware with the last versión, it would support ADSL2+?.
