Local authorization configuration
Answered Question
Oct 23rd, 2009
I have our ASA's authenticating against ACS (tacacs+) and using ACS authorization which all works, but when the ACS server is unavailable I can log in using local authentication but I have no authorization rights. Is there a way to grant full authorization rights to the local user if ACS is unavailable?
I am using
aaa authentication ssh console <tacacs> LOCAL
aaa authorization ssh console <tacacs> LOCAL
Correct Answer by Jatin Katyal about 7 years 9 months ago
You should have a local user on the ASA with privilege 15
You can add local user like this:
(config)#username password privilege 15
so this user account will have full access when your tacacs goes down.
JK
Plz rate helpful posts-
Overall Rating: 5 (2 ratings)
Correct Answer
Jatin Katyal Fri, 10/23/2009 - 12:13
  • Cisco Employee,
JK
networker99 Fri, 10/23/2009 - 12:21
Yea I did have that user.. it was becuase I had not fully logged out after applying the commands.. all okay now.. thanks
