3800 service-module session won't connect
Oct 23rd, 2009
I always have problems with this when configuring 3845s with a Switching module.
From what I understand, you just need to IP the interface gi2/0, and you're good to go, but I keep getting this:
mdf-rt-01#service-module gi2/0 session
Trying 10.52.240.1, 2130 ...
Here is relevant config:
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
no ip address
shutdown
duplex auto
speed auto
media-type rj45
interface GigabitEthernet2/0
description INTERNAL_ETHERNET_SWITCH_MODULE
ip address 10.52.240.1 255.255.240.0
ip verify unicast source reachable-via rx allow-default
ip helper-address 10.128.5.59
ip helper-address 10.128.5.50
no ip redirects
no ip unreachables
ip nbar protocol-discovery
ip pim sparse-mode
paolo bevilacqua Fri, 10/23/2009 - 12:25
  • Hall of Fame,
    Founding Member
Which exact module is this? "show diag" if you are not sure.
davebornack Fri, 10/23/2009 - 12:28
My apologies:
Slot 2:
NME-XD-24ES-1S-P: EtherSwitch SM 24 10/100T PoE + 1 SFP + StackWise Port adapter, 1 port
Port adapter is analyzed
Port adapter insertion time 04:00:11 ago
EEPROM contents at hardware discovery:
Hardware Revision : 1.0
Top Assy. Part Number : 800-25012-02
Board Revision : A0
Deviation Number : 10-1987
Fab Version : 03
PCB Serial Number : FOCxxxxxxx
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Product (FRU) Number : NME-XD-24ES-1S-P
Version Identifier : V02
Base MAC Address : 0025.84db.f300
MAC Address block size : 128
EEPROM format version 4
leo.laohoo Sun, 10/25/2009 - 14:43
Try removing all the config on Gig 2/0 (default interface Gig 2/0) and just put the IP address.
