How to replace "cry key generate rsa" when one key is already in place
Answered Question
Oct 23rd, 2009
Folks, I need to paste this config/templace on switches. When there is no cry key gen rsa already in place in the switch, the command works accordingly. If there is a key already in place, then I get prompted for "yes/no" and then I need to enter "800" to select the length I want.
Question: is there any way to force the command below to input "YES" and "800" when I get such prompt?
!-This one works well if no cry key is in place.
[pick 800] ssh_rsa_verify: RSA modulus too small: 512 < minimum 768 bits
!- As you can see, if pasted onto a switch which already has the key it hangs there waiting for a command prompt input.
myswitch(config)#cry key generate rsa
% You already have RSA keys defined named domain.c
% Do you really want to replace them? [yes/no]: yes
Choose the size of the key modulus in the range of 360 to 2048 for your
General Purpose Keys. Choosing a key modulus greater than 512 may take
a few minutes.
How many bits in the modulus [512]: 800
Correct Answer by Joe Clarke about 7 years 3 months ago
Enter the whole command in one shot:
crypto key generate rsa general-keys modulus 800
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Fri, 10/23/2009 - 13:15
Correct Answer
