i delete the flash memory!!! help me.
darojas16
by mistake I deleted the flash memory  I reinstalled the IOS in order to install the  software package UC520-7.0.3.zip
the problem is when I attempt to upgrade using the  Cisco configuration asistant application in the 49 per cent of the ipgrade proccess the installation failded indicating the following error:
Backup of CUE configuration and data failed.
Software upgrade for CUE module failed.
any help will be good
regards
Daniel Rojas
Hewlett-Packard telecom
Saurabh Verma
Level 4
Level 4
Hi Daniel,
You may have an FTP server running because of which CCA is not able to backup the configuration. Can you capture the complete application log for upgrade?
Saurabh
it is the error!!
picture 1 :i not have a FTP server running!!!
i select the option IOS, and this happens
Can you open up a command prompt and post the results of a netstat -an?
Steven DiStefano
Make sure you meet all these prerequisites and starting point for CCA connection...
https://supportforums.cisco.com/docs/DOC-9779
