Subinterfaces: point/multipoint
Oct 23rd, 2009
When I'm setting up subinterfaces in my frame-relay lab; does specifying the subinterface type (point-to-point | multipoint) do anything other than cause the OSPF default config, appropriate to that subinterface type, take effect?
Jerry Ye Fri, 10/23/2009 - 19:01
It will affect how your configure your DLCI.
Point-to-point uses the frame-relay interface-dlci xx command.
Multipoint uses the frame-relay map command (like configuring frame-relay on the physical interface).
