static route ll work?
Oct 24th, 2009
hi friends,
i am having tunnel between dubaicenteral to spain and its working fine and also i am having tunnel between dubaicenteral to dubai remote site.
my question is if i add a static route in the dubai remote side i can able to access on spain network?.if its not possible tell me the way how i can connect.
thanks
Paolo Bevilacqua Sat, 10/24/2009 - 02:25
Yes, it is possible.
Recommend that you avoid static routes, use a routing protocol instead.
zeuscyril Sat, 10/24/2009 - 03:10
i can use ospf or rip protocol
i need to mention the networks in the routing protocols
is it correct.
Paolo Bevilacqua Sat, 10/24/2009 - 03:33
It is.
However if you do not have experience or certification in networking, recommend you consult a professional for best results.
