local Subscribers vs. remote Subscribers for Large Sites
Hi Team,
in a centralized CUCM Cluster significant bandwidth is needed for connection of large sites (> 2000 users) to the central applications.
I try to find out, if its better in type of WAN bandwidth and stability
1) to design a Cluster over WAN with local Subscribers and reduce the traffic between phones and Call-Processors but having the Cluster over WAN requirements on the WAN
2) centralize all subscribers
The SRND bandwidth calculations do not
finally judge me.
My feeling says that the Cluster-over-WAN is more batch-traffic and can revover after a WAN failure without large user impact where as the Phone-to-Subscriber traffic is more
real-time and a problem on the WAN
may lead to SRST toggeling, so local Subscribers might be more reliable.
Any comment or better experience is highly welcome...
best regards,
rob.huffman Sun, 10/25/2009 - 08:26
Hi Alfred,
For large sites, like you nicely noted, I would use "local" Subscribers as a Best Practice :)
These guides should be followed when planning;
Multisite with Distributed Call Processing
And this is really your best bet!
Local Failover Deployment Model
Hope this helps!
Hi Rob,
thx for your comment.
To be a little more precise from my side. As long as this would be possible I would like to stay on one Cluster or Supercluster. Having 6 of these large sites with a local subscriber and remote failover the Cluster over WAN would consume 7 Mbps from Publisher to each site, means > 42 Mbps, assuming the Calculation from the the SRND Example 2-1.
