SPA3102 accepting SIP registrations from
Oct 24th, 2009
I have just set up a SPA3102 on my internal network, and have connected it to the PSTN.
I want to be able to route incoming calls on the PSTN to a IP phone (a Snom 360), and also make outgoing PSTN calls on the Snon. For the moment, it is just one IP phone, but I do want to add further phones in later.
However, the Snom only seems to be able to do this if it is registered through SIP, but I can not see how you can accept SIP registrations on the SPA3102.
Does any one have any sugestions or advice please.
Many thanks
Gee
Alberto Montilla Mon, 10/26/2009 - 04:35
  • Cisco Employee,
Dear Sir;
SPA3102 does not accept registrations, it has to be a peer-to-peer SIP trunks (no registration). I'm not sure SNOM supports this configuration, but I would suggest you check it with them.
Alberto
Related Content
