UCCX instalation problem
Oct 24th, 2009
Dear all
I have UCCX version 7 , when i want to install on my MCS it returns an error that the server is not Cisco approved
while my box is MCS with win-os 2003.1.2
any idea?
Overall Rating: 4 (1 ratings)
hani-molani Sat, 10/24/2009 - 11:19
no its the correct mcs
right now i have also cisco unity installed
it mcs7835h2
James Hawkins Sat, 10/24/2009 - 12:48
Are you re-installing from scratch using the Windows Server 2003 OS disk included with UCCX7 or just trying to install UCCX on a server that already has Windows 2003 installed? - maybe the OSA that shipped with Unity?
If the latter then that will not work - you need to use the OS supplied with UCCX.
neil.woolloff Thu, 12/31/2009 - 06:53
Is that correct James.
I as becasue the only way I can get an HP DL320 G4 to build is with the Unity build disc.
If it must be the UCCX build disc, I'll have a look for it.
Weird as the only erro rthe log says is not enough disc space.  Needs at least 4GB free when the box has over 65GB free.
