VPN 3000 and oracle problems.
Oct 24th, 2009
I am facing a kind of problem with VPN 3000 concentrators after upgrading the code to 4.7.
The problem is, after I login through the webvpn portal and try to access my financial application running oracle app, it stops with an error. The error message is attached.
any suggesstions?
slmansfield Tue, 10/27/2009 - 07:02
I'm not sure why the software upgrade would prevent access to your application. Did you verify that your Oracle servers can reach your VPN client by its assigned address?
