Is there any WAN fiber module for router 2800?
Answered Question
Oct 24th, 2009
Folks, I know 2800 routers are designed to handle less than 20Mbps WAN links.
Someone told there is a fiber module (in which I could connect fiber directly to the 2800 router module). I can't find such module so far.
Anyone can confirm whether there is such fiber module/connector for 2800?
Correct Answer by Giuseppe Larosa about 7 years 3 months ago
Hello Marlon,
what are looking for?
a GE with fiber optic to be used as WAN port.
Or you are looking for a real WAN port that is fiber based:
the second means:
ATM or POS STM-1 155 Mbps as a minimum and it is not supported on this class of devices
see
http://www.cisco.com/en/US/prod/collateral/routers/ps5854/ps5882/product_data_sheet0900aecd8016fa68_ps5854_Products_Data_Sheet.html
you can have up to serial E3/T3 or ATM E3/T3 but these are based on BNC.
To be noted that WAN provider can usually deploy some external device to carry an E3 or T3 over fiber.
if you look for a GE fiber based module some etherswitch module supports it, but they are too expensive and in this case I would look for an external media converter
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Paolo Bevilacqua Sat, 10/24/2009 - 11:29
Which exact router? There are 4 models in the 2800 series. And, everything is explained in the data sheet.
Correct Answer
Giuseppe Larosa Sat, 10/24/2009 - 11:31
Hello Marlon,
the second means:
see
Hope to help
Giuseppe
news2010a Sat, 10/24/2009 - 14:52
In this case it would be a GE with fiber optic adapter to be used a WAN port.
In this case it would be a 2845. Thanks for the explanation.
Leo Laohoo Sun, 10/25/2009 - 14:50
Yes there is! It's a mutant between a 3745 and a 2800. No Data Sheet included.
He he he ...
whit_richardson Tue, 10/27/2009 - 06:38
If you want to run fiber based WAN, i.e. OC3 etc. you should use the 3800 series like the 3825 or 3845. They can be had for a decent price for used. 2800's are branch routers and Cisco doesn't expect branches run anything over IMA bundles.
