ACE - active/standby
Oct 24th, 2009
Hi Experts,
I have Two ACE modules in bridge mode and its configured as active/standby.
But I cannot ping to the gateway from standby ACE. from the msfc side all the configurations are ok.
Could you plz help us to find the root cause of this ?
Rgds
Aslam
sachinga.hcl Mon, 10/26/2009 - 00:37
  • Silver, 250 points or more
Hi Aslam,
Can you please send me the config details of you admin Context by sending the output of the following commands:
# Show running-configuration
and
# show run ft
and # show ft group detail
I think there is some VLAN problem in your case either configured incorrectly or not included
Can you send your design
Like sample as follows:
FWSM--vlan 7--ACE-vlan 8---servers with default gateway as FWSM
Can you post the output for
show int vlan 505
sh arp
are you running ACE on a C6500 VSS pair?
Do you have an ip in your ACE vlan ?
If both of the device you are trying to ping are in the same VLAN as in ACE it does NOT route between VLANs so you cannot ping the interfaces in different VLANs.
Kindly send your config without which it will be difficult to figure out the exact root cause of your problem or any configuration mismatch.
Sachin Garg
aslamta123 Mon, 10/26/2009 - 01:35
Hi Sachin,
Thanks for the reply .. My issue has been resolved, It was due to the missing IP for the peer BVI interface..
Rgds
Aslam..
