access-list
Oct 25th, 2009
It is a carrier spportin carrier topology
A---DS----CORE---ISP/PE--P----PE---B
Am classifying traffic on core for a particular customer A by standard access-list.access-list 10 permit 10.10.10.1 0.0.0.7 This is the IP address configured on DS switch facing to customer A.
Am calling this access-list in class-map for classification of traffic and am doing policing for traffic at 2 MBps,at egreess interface on core facing to ISP router.
The connection to ISP is back to back VRF.i have created a virtual interface on core for each customer and a layer 2 trunk is connected to ISP router.
WHen i do a extended ping vrf for customer B from DS with source IP of access-list configured i dont see any hit counts on access-list.
Can any body help.
Overall Rating: 5 (1 ratings)
Edison Ortiz Sun, 10/25/2009 - 19:40
If you are dealing with a Catalyst switch, you won't see any counters on the 'policy-map interface' output as those counters are software counters and QoS is done in hardware.
You must use the 'show mls qos' command
http://www.cisco.com/en/US/docs/ios/qos/command/reference/qos_s4.html#wp1084023
"The output does not display policed-counter information; 0 is displayed in its place (for example, 0 packets, 0 bytes). To display dropped and forwarded policed-counter information, enter the show mls qos command. "
Edison
adamgibs7 Mon, 10/26/2009 - 03:23
The configs are on Core.
Extended IP access list 101
10 permit ip 10.10.10.0 0.0.0.7 host 10.30.30.1
CORE#sh class-map test
Class Map match-all test (id 1)
Match access-group 101
Class Map match-any class-default (id 0)
Match any
CORE #sh policy-map 4MB
Policy Map 4MB
Class test
police cir 4000000 bc 125000 be 125000
conform-action transmit
exceed-action transmit
violate-action drop
CORE #sh run int vlan X
Building configuration...
Current configuration : 202 bytes
interface Vlan X
description connected to ISP for A
ip vrf forwarding A
ip address 10.X.X.X 255.255.255.254
ip flow ingress
service-policy output 4MB
end
DIST#sh run int gig3/1
Current configuration : 174 bytes
interface GigabitEthernet3/1
description Connected to link customer A
ip vrf forwarding A
ip address 10.10.10.1 255.255.255.248
