Cisco 3825 router rebooted
Oct 25th, 2009
One of our 3825 (IOS ver 12.4(12)) router rebooted automatically.It is confirmed that there was no power issue/cable disturbance happened at that time but i want 2 know what went wrong...issued sh env all command but no probs found..can anyone guide 2 identify the root cause...
Here is the o/p of sh env all
My_router#sh env all
Redundant Power System is not present.
SYS PS1 is present.
Type: AC
AUX(-48V) PS1 is absent.
Fan 1 Normal
Fan 2 Normal
Fan 3 Normal
Fan Speed is Normal
Alert settings:
Intake temperature warning: Enabled, Threshold: 55
Core temperature warning: Enabled, Threshold: 70 (CPU: 95)
Board Temperature: Normal
Internal-ambient temperature = 29, Normal
CPU temperature = 46, Normal
Intake temperature = 29, Normal
Voltage 1(3300) is Normal, Current voltage = 3316 mV
Voltage 2(5150) is Normal, Current voltage = 5153 mV
Voltage 3(2500) is Normal, Current voltage = 2525 mV
Voltage 4(1200) is Normal, Current voltage = 1215 mV
Nominal frequency
paolo bevilacqua Sun, 10/25/2009 - 14:39
  • Hall of Fame,
    Founding Member
Show ver, show stack, and you will see the software crash.
But, you need a support contract to update the buggy IOS.
Leo Laohoo Sun, 10/25/2009 - 14:48
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Check your flash if you can find any "crashinfo" files/sub-directory. If there is one present, can you post it?
edaisal123 Sun, 10/25/2009 - 19:57
Hi All,
I don't see any crashinfo in my flash directory..
My_Router#sh flash:
-#- --length-- -----date/time------ path
1 17594524 Jan 11 2005 09:22:16 +05:30 c3825-advsecurityk9-mz.123-11.T2.bin
2 1541 Jan 11 2005 09:28:58 +05:30 sdmconfig-38xx.cfg
3 3885056 Jan 11 2005 09:29:22 +05:30 sdm.tar
4 1463 Jan 11 2005 09:29:32 +05:30 home.html
5 270848 Jan 11 2005 09:29:46 +05:30 home.tar
6 93095 Jan 11 2005 09:30:00 +05:30 attack-drop.sdf
7 1187840 Jan 11 2005 09:30:16 +05:30 ips.tar
8 36673864 May 21 2007 04:31:48 +05:30 c3825-advipservicesk9-mz.124-12.bin
My_Router#sh stack
Minimum process stacks:
Free/Size Name
5464/6000 Inspect Init Msg
5412/6000 SPAN Subsystem
5140/6000 DIB error message
1928/3000 allegro libretto init
10648/12000 Router Init
2784/12000 Init
59208/60000 script background loader
5256/6000 RADIUS INITCONFIG
2148/3000 Rom Random Update Process
8416/12000 SSH Process
Interrupt level stacks:
Level Called Unused/Size Name
1 115625368 6480/9000 Network interfaces
2 56837878 8592/9000 DMA/Timer Interrupt
3 1 8624/9000 PA Management Int Handler
4 9 8600/9000 Console Uart
5 0 9000/9000 External Interrupt
7 49787295 8560/9000 NMI Interrupt Handler
4161536 bytes available (59723776 bytes used)
My_Router#sh ver
Cisco IOS Software, 3800 Software (C3825-ADVIPSERVICESK9-M), Version 12.4(12), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Fri 17-Nov-06 15:31 by prod_rel_team
ROM: System Bootstrap, Version 12.3(11r)T1, RELEASE SOFTWARE (fc1)
My_Router uptime is 2 days, 7 hours, 19 minutes
System restarted at 01:07:21 IST Sat Oct 24 2009
System image file is "flash:c3825-advipservicesk9-mz.124-12.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Cisco 3825 (revision 1.0) with 225280K/36864K bytes of memory.
Processor board ID FHK0903F18Q
2 Gigabit Ethernet interfaces
16 Serial interfaces
6 Channelized E1/PRI ports
2 Channelized T1/PRI ports
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
479K bytes of NVRAM.
62592K bytes of ATA System CompactFlash (Read/Write)
Leo Laohoo Sun, 10/25/2009 - 22:17
  • Hall of Fame,
    2017 LAN, Wireless
Doesn't say anything about a crash or something but rather a power failure.
