10-25-2009 06:29 PM
My standby ACE has gone to unresponsive mode and shows something like this
peer state: FSM_FT_STATE_UNKNOWN
This is for all the contexts in the slot module. My question is how do we bring it back to HOT_STANDBY when all contexts are unresponsive
AND
How do we bring it to HOT_STANDBY when just one context is unresponsive
SID
10-26-2009 12:13 AM
HI Sid,
It is very similar to the previous response of your query.
As I am seeing one error message here in your mail:
Upon failure of the fault tolerant link between Services Chassis's the peer standby ACE begins to query the status of its peer active ACE. Six consecutive ping requests occur approximately every five seconds across the query interface VLAN while the fault tolerant link is down. The output from the show ft group detail command shown below indicates that the fault tolerant link is down; the primary peer state is unknown but the primary peer is still reachable. As a result, the standby peer remains in FSM_FT_STATE_STANDBY_COLD. When the fault tolerant link is recovered the query ping tests cease.
dca-ss2-ace/Admin# show ft group detail
FT Group : 1
No. of Contexts : 1
Context Name : Admin
Context Id : 0
Configured Status : in-service
Maintenance mode : MAINT_MODE_OFF
My State : FSM_FT_STATE_STANDBY_COLD
My Config Priority : 50
My Net Priority : 50
My Preempt : Enabled
Peer State : FSM_FT_STATE_UNKNOWN
Peer Config Priority : Unknown
Peer Net Priority : Unknown
Peer Preempt : Unknown
Peer Id : 1
Last State Change time : Wed Jun 11 14:46:08 2008
Running cfg sync enabled : Disabled
Running cfg sync status : FT Vlan Down or TL down. Peer may be reachable through
alternate interface
Startup cfg sync enabled : Disabled
Startup cfg sync status : FT Vlan Down or TL down. Peer may be reachable through
alternate interface
Bulk sync done for ARP: 0
Bulk sync done for LB: 0
Bulk sync done for ICM: 0
FT Group : 2
No. of Contexts : 1
Context Name : dca-ace-one
Context Id : 1
Peer Id : 1
alternate interface
alternate interface
All fault tolerant groups will honor the results of the query tests and remain in a FSM_FT_STATE_STANDBY_COLD state on the standby peer ACE.
The Admin context allows the network administrator to assemble virtual contexts into failover groups. A failover group is a container, which permits a pair of ACE modules to define several failover characteristics and apply them to all virtual context assigned to the container, including the Admin context. These defining features include:
â¢The associated peer ACE
â¢The priority or preference value for each ACE module in the redundant pairing
â¢Preemption (enabled by default)
â¢The virtual context(s) coupled to the group
Sachin Garg
10-26-2009 12:14 AM
contd....
Below is an example of the failover groups used during testing. The failover group has an associated peer and priorities. Note that the higher priority ACE module will be the primary platform for the active virtual context associated with the fault tolerant group. Preemption enforces this preference during service recovery and is not visible in the command line output unless disabled.
On Primary
ft group 1
peer 1
priority 150
peer priority 50
associate-context Admin
inservice
On Standby
ft group 1
peer 1
priority 50
peer priority 150
inservice
The tracking features of the ACE can decrement the failover group priority value allowing intelligent and conditional graceful failover between modules. The fault tracking features in this design will be documented under the ACE Virtual Context Configuration section, but it is important to understand that the priority or module preference definition is found under the failover group construct.
This error appears if you have not given the correct priority for the ft group on both of the Primary and Secondary.
ACE features configuration synchronization between peers. This means only a limited set of interface and fault tolerant configuration is necessary on the peer ACE to match the primary ACE configuration through this automated feature. Configuration synchronization applies to all contexts including the Admin context.
Sachin Garg
10-26-2009 06:09 AM
Hi Sachin,
Could you outline the procedure to reload the ACE and in which order do we give it on the ACES?
When we manually sync the configs is it necessary to reload the ACE?
Thanks in advance
